LDH has not come up with a way to cal these?The throttle position sensor is installed and calibrated with the throttle body assembly.
So if the TPS goes bad, you'll have to install the entire throttle body assembly.
If you try to swap out the TPS from another throttle body, there's no procedure to calibrate the TPS.
So you did find the cause of your blinking FI light then.And I do not have an fi light on. I did but due to the map not being connected
