Where's the squeak coming from? I tend to remove the two screws to take off the throttle cover on the twist grip and use some oil to lube it up and let it go down the cable. This should fix your problem. It's pretty easy and I don't recommend WD40 use something like engine oil. When you do I keep rolling the throttle back an forth to help the oil go down into the cable.
Sent from Motorcycle.com Free App sucks balls!!! Omfg it won't stop opening the f'in App Store!
