Hello, the bike is now running great but I noticed today that the tripmeter resets to zero every time you turn the ignition on and off? Any suggestions/solutions greatly appreciated. Regards Andy.
probably needs a new battery, dropping below min voltage when turned off.
  • Like
Reactions: theottergod
check the "odometer" fuse
check the red/green wire for battery voltage at the dash harness
check the big grey connector for corrosion on the red/green wire
if these are all good, put a multimeter on the battery and crank the bike with the kill switch off to see what your voltage dips to while cranking.
