1 - 12 of 12 Posts
Hi Guys,
I have just fitted an underslung caliper to the SP2 (Thanks to SBK Drew!!:grin2:), Im looking to secure the brake line against the bottom of the swingarm.. I'm loathed to drill the arm :crying: but if needs must in the absence of any non invasive suggestions?
If I have to drill the arm, what/how do you recommend the best way of doing it, some sort of captive threaded insert?
Thanks in advance
Jay
you can use the same rubber nutserts (wellnut) like the ones used on the bodywork, the lowers to the upper.
Some hardware stores carry the stanadrad thread ones but not metric. Go with something like a m5 size screw insert and drill a hole accordingly...Measure twice, drill once, no worries...I'm doing the same to install a foot/chain guard....
i just ran a self tapping screw into the bottom of mine. that way i have a 1/8th hole instead of a 3/8s hole. i don't think anything fixed with adhesive would stand the test of time under there.
Clean the inside of the swing arm good with some alcohol and use a sticky back with a tyrap . works great that what I did on mine , No extra holes
  • Like
Reactions: MJay
For xtra stickiness run a heat gun over the metal just a touch and then apply the sticky back and let it sit an hour before cinching up the brakeline with a tyrap , and leave a little slack for movement of the swingarm
  • Like
Reactions: MJay
Thanks for the answers guys, I am going to try the adhesive route first, I have some very powerful sticky pads to use firstly, if that fails then I will go down the drilling route. :)
I made a simple bracket out of some scrap aluminium - which screws together with one of the tabs for the hugger onto the swing arm. Zip ties hold the hose onto the bracket. No drilling required & it's invisible too.
I don't know why anyone would want to run it underneath, since the m/c comes out at the top of the arm, but each to his own. Mine just goes directly through the hugger, then diagonally down and to the m/c.
Here's a few older pics, with the bike before I fitted some billet Brembos.
There will be a fair few areas where the hose could chaff behind the rear set with vibrations, etc. when riding unless the hose is securely fastened but I'm sure you figured it out. Looks neat indeed.
1 - 12 of 12 Posts
