1 - 15 of 15 Posts
So, I'm at 15.3k miles, and I'm pushing the need for a valve adjustment, I really don't want to pay 500 bucks to get it done, but I have no idea how to do it myself, what do I need at the least, and how do I do it?
Foremost, the service manual.
Then a good quality calibrated torque wrench.
A set of feeler gauges. The short ones are easier to get into tight spaces.
A set of metric sockets.
A shim kit, or you can obtain shims from the dealer.
Clean shop rags.
A flashlight would be good too.
It's not too difficult with the tools.
Start with the front cylinder. Once done, it's only a 270 deg rotation to align the rear cylinder.
Make sure the bike is clean and dry around the areas.
Since you'll have the valve covers off, it's not to difficult for dirt or foreign objects to fall into the valve area with dire results.
Lay your parts out as you remove them. Two of the three cam journal caps are marked for intake or exhaust. Don't confuse them.
Of those of us who have done this adjustment ourselves, how many have found the shims actaully did need changing after checking clearances?
Furthermore, are there any tricks to doing this? Or do I basically have to do it by the numbers from the manual? And yeah, I'm curious about Stig's question, too.
I had to change two shims the last go 'round (36K mile).
One exhaust was too tight, and one intake was too loose on #1 cylinder.
So, I was talking to a service manager at a shop and I asked him why a valve job was so expensive, and he mentioned something about having to remove one of the radiators, but the service manual mentions nothing about that
A valve job is totally different than valve adjustment.
A valve job is basically due to wear on the valve seats over time.
The valves wear into the valve seat and begin to not properly seal well.
The valve seat is reamed to regain a 45 degree angle seat angle to mate with the valve head.
This requires cylinder head removal.
If worn too badly, the valve seat is removed and replaced, then reamed to properly mate with the valve head, which may also be replaced if needed.
Oh, he must've mistaken my question, and at only 15k miles, I shouldn't need a valve job, just a valve adjustment.
tiny little valves all over the place
It is the size of the valve that matters
cbr929 rc51
Intake Valve Diameter 29.0 mm 40mm
Exhaust Valve Diameter 24.0 mm 34mm
But how high you are revving an engine also matters
My cbr929 didnt need adjustment untill 50,000kms
1 - 15 of 15 Posts
