1 - 12 of 12 Posts
So i got the bike tore down trying to find out why she started to idle rough. I already changed the egr out and i am hoping that fixes the issue. But i was trying to see if a semi pair delete was done so i can finish it and i find this little guy. Can anyone tell me what ot is and what it does?
Thank you, so im guessing since my evap canister is missing i should finish the delete.
yeah just delete the pair by removing the pair valve, the hoses, install block off plates and plug the hole in the airbox.
to remove the flapper take the valve out of the intake and block the hole left over. remove the solenonid and all the vacuum hoses. then remove the vacuum canister and install a vacuum cap at the vacuum port on the front throttle body.
simple enough.
134785
Okay, i thinj i have the california model due to the throttle body, dont mind the dust, i do wood working and the wind took my cover.
what about the throttle body makes you think it's a california model.
the only difference between the A model and the AC is the evap canister.
the vacum lime on the throttle body and a mounting bracket missing an evap canister. i can be wromg about the throttle body.
well if it's already gone it doesnt matter.
you can remove the rest of the flapper assembly, just make sure you cap all unused vacuum connections.
Thats what i did today, any recommendatioms for capping the throttle body besides capping the hose? And this bike is been a fun fun process, see exibit a
134788
1 - 12 of 12 Posts
