I cleaned and inspected my bearings when I removed my swingarm during my engine swap out.
I found no roughness, deformation, or discoloration and they all seemed smooth when rotated.
So I replaced the seals and packed them with synthetic hi-pressure moly-based grease.
I still have the replacement bearings if I need them.
awesome, mines is an sp2 swingarm on an sp1 frame. should i need the sp2 bearings and dust cover setup, the sp1, or are they both the same anyway?
The bearing sizes differ between the SP1 and SP2 due to smaller diameter pivot bolt on the SP2.
I'd would think you're using SP2 size bearings in the swingarm.
