1 - 20 of 29 Posts
Ok, so here's my situation. ON tuesday, I'm on my way to work. I stop the get gas, turn the bike off. Fill up, now bike won't start. Try to push start, no luck. Get it towed to shop, they put it on the battery charger. And they say "they think it's the battery". They charge it over night, but I don't have a chance to pick it up until thrusday. I get the bike home, all seems good. I shut it off, start it up a few times and no issue.
Ride it to work on friday, starts up with no issues. Come out from work 8hrs later to go home, won't start. Have to push start it. Get maybe 10 minutes from home, and the gas warning light starts to flicker. Get maybe 1/2 a mile down the road, get ready to pull off from the light and it shuts off on me. Try to start it up, and no luck. All the lights on the dash come on, but Doesn't click, fuel pump doesn't prime, and won't turn over. Let it sit for awhile, try to start it up. Fuel pump primes, try to start it up and all I hear is "click click click" but wont turn over. I have a friend come and help me look over everything. Check the battery connections, all is good. We get it push started again, let it run for awhile. Then it just shuts off on it's own.
Next I get it jump started, get the bike home. Pull in the driveway, leave it running. And the low fuel light start flickering again. Turn the bike off, try to start it back up. And nothing!!! Roll the bike into the garage, get it on the charger. Red light on charger comes on meaning it's charging. 20 minutes go by, I look out in the garage, and the battery is already charged. The green light is on meaning the charger is in "storage mode".
So I'm starting to think that it's not the battery. But something is pulling/draining the battery. Any idea what this could be?
its defo an electrical problem. i had something similar with mine a few months ago. i took it to my garage and me and my bro spent a few hours taking every connector we could find apart. disconnected, cleaned then dielectric greased every one of them.
helps all the connections work more efficiently and protects/insulates them against future weather/wet/wear.
if you wanna just do the connectors causing the prob and leave the rest, id work through all the wiring under the tail.
p.s also check the 30amp fuse on top of the battery is ok too.
I'd start with checking the main fuse & charging system for correct voltage readings. How to do this should be in the workshop manual, which is downloadable somewhere. Sorry I haven't downloaded it so I can't tell you where - but a search on here should reveal.
Checked all the connections, but didn't test to voltage. Only issue I found was my right front turn signal is not working. Took it to the gas station, cut it off. Filled it up, fired right back up. Came home, shut off. Turn it back on. Did that a few times, and everything seemed fine. So decided to go for a little longer ride. Maybe 10 minutes. Come back home, shut it off. Try to turn it back on, and no luck.
I did happen to find this when I took the tail section off. Anybody know what it is?
I'm not near my bike, so it's just a guess but this could be the tip-over sensor's connector perhaps...
You need to check if it's charging correctly or not first.
I don't have a manual, so I don't have the proper procedure here - but the easiest way would be to connect a multimeter across the battery (Red to +ve & black to -ve) and see the battery voltage first (Around 13V on a fully charged battery would be around the right figure). Then as it starts - see if it's getting around 14v when the engine is started. gradually increase revs to around 4,000 and see if the voltage increases slightly. It should - but nothing above around 14.5v. If there's no change in voltage as the bike is started - then there's either a bad connection or your charging circuit is faulty I'd say...
Also before doing the above - check the connections for the battery (Take them off, sand & refit, not just a visual check) and other connectors too. There's another connector for the main fuse - which if dislocated will cause the fuel pump not to prime when the ignition key is switched on. All connections should be clean & firmly connected. You might want to get some di-electric grease to use on connections for protection.
The Voltage test is for when you've checked the obvious connections for good contact.
HTH
Stig
So after it died this time. I put it back on the charger. And the battery is still charging. So now I'm starting to wonder if it is just a bad battery. Last night it switched from "charged" to "storage" after like 20 minutes
It could be a bad battery, but usually they perform better immediately after being charged by the bike, not worse.... So they should show weakness especially after a while left alone, not when the starter is engaged very shortly after the bike's been switched off. Also doesn't explain why the bike's fuel light flickers, etc.
Try what I've suggested. You'll be closer to the reason for your problems there I suspect...
its process of elimination with these things. its strange how something always seems to happen when your fueling it up. does the bike have an alarm? like a datatool?
First of all, ghe green connector is the service connector. It is supposed to be like that , so no worries there.
Second; I am 99% sure you need to replace the regulator/ rectifier unit. It is a common problem. I would suggest going for a more modern MOS-FET based unit.
Third; Your battery is probably toast due to the faulty regulator.
That's where I would start.
Heres a link the R/R mod
http://www.rc51forums.com/forums/showthread.php?t=6540
Discussion Starter #15
I'm goin to buy a voltmeter and run through all the connections again. Think I might just buy a rectifier even if its not the issue. On my old gixxer, that was one if the first things that went on that bike. So I always felt Gavin those laying around was a good thing
Discussion Starter #16
A thought just crossed my path!!! When i went and picked up the bike, I noticed that the owner of the shop kept starting the bike and it was cutting off. He didn't know about the cold start choke. So Is it possible that if they didn't realize this. Could them trying to start the bike over and over again like that kill the battery??? Or maybe even the startor/stator relay? Which could possibly drain the battery??? Just a thought
Sounds like a R/R issue. When weird electrical things start happening that's usually the culprit. Replace it before your battery gets toasted and go from there.
Just a side note and add to Hotbrakes' post
My PC3 would drop the map and just go crazy. Outlined here
When I upgraded my R/R, the PC3 started working right
James
1 - 20 of 29 Posts
