1 - 14 of 14 Posts
I've been looking for the company that makes a undertail without lights. I've seen it somewhere recently but I cannot find it again it was pictured in red with a hrc sticker on it and I think silver also. Thanks
Get a sheet of lexan, plastic, whatever you want and make your own. Just lay your tail down on a piece of cardboard and trace the inside of the opening onto it. Then add a 1/8 to 1/4 inch around the edge and cut that out. Trace it onto the plastic and there you go.
It is easy and will only cost you time and about $20. Thats what I did:
Thanks b.miller, That was the one I was trying to find I emailed him and have yet to hear anything. I'll probably go the rout of making my own. I like the look of yours did you also make a battery box ? I plan on making a detachable unit for my tail lights.
The stock fender was still in place, well what is left of it was. So no need to make a battery box. Since mine is an SP2, te ECU had to be moved to get the bottom completely flat though.
The light on mine was a 04-07 cbr1000 tail light with the lense removed. It was placed behind the tinted lexan:
It was plenty visible, but if I did it over I would use clear lexan and paint the lower part that way the light has nothing blocking it. I noticed on really sunny days it was a little difficult to see.
Hey B Miller ...love that undertail....can you help me do my bike that way ?
That's a pretty neat way of doing tail lights are they still bright enough to be seen in daylight ? Have you ever had any trouble with the police not thinking there so neat ?
I bought the tinted lexan at home depot (it might have been acrylic, not too sure). Buy a big sheet, as it does tend to crack pretty easy. I used a dremel to cut it, but a jigsaw would be much easier.
Raleigh, I wouldn't mind helping but I just accepted a new job in Seattle and I'm starting in less than a month. I probably won't have much time the next few weekends as I prepare for the move.
The lights were visible, but I think clear would be a better option. I was going to redo it with a clear piece and paint the inside below the light black. Cops were never a problem with it, although I am a pretty tame rider on the street and cops in TX really don't care about things like that. In Washington state they were a little more picky, so who knows.
Administrator
Great job...really like the looks of it! I know you can buy an aftermarket rear light for those CBR's that also have integrated blinkers. How did you secure the piece of Lexan?
Moving to Seattle will definitely cut down on the length of your riding season
Yeah, but the 55% raise makes it easier to swallow. I'm from the area, so I'm no stranger to riding in the rain. Makes you a much better/smoother rider.
Sorry for the threadjack.
I was going to pick up one of those before I street fightered the bike.
The lexan is just a bit bigger than the opening, so it doesn't fall through. I used the stock holes on either side of the bottom of the tail. I used dzus fasteners, but anything would work. The very back of the lexan can be pushed into the tail a little, but it never really bothered me. I suppose you could put some double stick tape in between the two.
I did eventually cut a hole and stick a CBR tail light trough the lexan, but it didn't turn out a well as I would have liked. The CBR light needs to be more angled up than our tail, so it was pretty difficult to get it aimed right. If I did it again, I'd keep it on the inside, looks better that way anyways.
1 - 14 of 14 Posts
