Ok well I got tired of waiting, and got the book. Jumped the plug to get the trouble shoot codes. 2,3,4,5,8,9..... The throttle positioning sensor, and TI are the 2 codes that are the major ones. Followed the book down to the harness computer factory trouble shooting harness needs. Everything checks out fine to the ECU. So I tried to follow the trigger wires off the cam and the crank. Not getting any signal from the ECO. Not getting signal to the coils. Swapped out ECU, and Converter unit. Still nothing. So any guesses? I tried bypassing the neutral safety, clutch switch, kick stand switch, nothing! The Angle relays are all good, and working. I get no ignition!!! GRRRRRR The fuel pump is priming.
